Efi Fiesta Turbo Into Efi Escort
Guest lutonman12
Guest lutonman12
hi this has probably been asked b4 but how much work is needed to put a frst into my efi escort is it just a matter of changing every thing over(ecu etc??)wot about the fuel pump ,as my car was originally mfi and im still using the original fuel pump(under the car not in the tank)any help would be appreciated
  • Admin
Just in the process of doing mine. If you need help just ask.
The first hurdle is finding a Escort EFI wiring loom, the fuel pump will need to be upgraded but this is a easy job.
Paul
Guest lutonman12
Paul
mines got an efi loom with the ecu etc...(WAS mfi but converted to efi in my c reg mk3 cab)if i get a fiesta lump can i keep my loom and just change the ecu?....fuel pumps a funny thing i was told it was not possible to run efi with mfi pump but it works fine!!!so i would expect it to be cool runnin the fiesta lump!!??wot u reckon??
  • Admin
You will need to upgrade your fuel pump. Everything else will drop straight in. But you will need a OFAB or OFAC ECU and map sensor.
Paul
  • Admin
You will also need the Air Charge Sensor from the Fiesta Turbo if you are using your standad EFI inlet. There are some pin changes on the ECU but sepends if you run OFAB or OFAC. I have pin outs if needed.
Paul
Guest lutonman12
Paul
im gonna try and get a battered/rotten fiesta so i should get these bits on it,apart from that sounds straight forward enough thanks 4 ur help
Guest smoothy582
mfi fuel pump will be fine for efi, most things are a strate swap, you will need to swap some pins on the ecu multi plug. all info can be found on www.rsbible.co.uk
Guest turbosy
MFi fuel pump is actually better than the EFi pump.......more fuel pressure!
Looms right, fezzy turbo engine, ECU (you need a few wires moving), air temp is different as is the map sensor
Guest turbosy
would i not have the pedal an cable already??
Yes should be ok, if its been changed to the EFi ones already
