Guest fastasfuk Posted April 5, 2008 Share Posted April 5, 2008 Hi peeps...My problem is to do with a fiesta rs turbo,i have tried other forums but no one could help me out so im hopeing that someone here might be able too help..Ok,my problem is that when i try to start my car,it just dies after a few seconds,now if i disconnect the pipe coming from the map sensor too the inlet manifold,it will start and run fine,by the way,im running ofac..i have changed the map sensor a couple of times but still the same problem..its a real head wrecker..Now i also have an ofab setup that i connected too the car and i have to do the same thing with the map sensor on that too...Any help would be great...Many thanks in advance Link to comment Share on other sites More sharing options...
Admin Paul Posted April 5, 2008 Admin Share Posted April 5, 2008 Silly question have you got the inline valve the right way? Paul Link to comment Share on other sites More sharing options...
