Starter Motor Wiring
Paul
There should be a thick red wire that goes to the starter (13mm nut) for the battery feed then a thin black wire (10mm nut or female spade terminal) ignition switiched feed on the starter. All of the above wires should be taped together as a separate loom What make is the alternator? (Motorcraft, bosch or carello)
Edited by ianxr3i
