Guest Justin Posted February 14, 2008 Share Posted February 14, 2008 got a problem with my headlights.. when i turn the switch to side lights, i get side lights. When i turn it to dipped beam, it dims.. Main beam is fine. Checked fuses in fuse box and checked bulbs. both seem fine. presumably though if bulbs had popped it would affect side lights or main beam too wouldnt it.. Im guessing an new indicator stalk would fix it, but thats a guess.. Anyone got any ideas? Justin Link to comment Share on other sites More sharing options...
Guest the chunkster Posted February 14, 2008 Share Posted February 14, 2008 try relay maybe on top of fuse box or inside engine bay its only a guess normally problem on me old mini Link to comment Share on other sites More sharing options...
Guest Justin Posted February 14, 2008 Share Posted February 14, 2008 try relay maybe on top of fuse box or inside engine bay its only a guess normally problem on me old mini how would i check to see if its ok? Is there a way of doing it without having to buy another one? Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted February 17, 2008 Share Posted February 17, 2008 if memory serves me correctly , put a 12v supply on terminal 85+86 which should be the coil. then use as multimeter to see if you get a connection between the switch contacts, failing that you can see if the coil is good by checking the resistance of it and compare with a similar one in the fusebox. hope this helps. Link to comment Share on other sites More sharing options...
Guest Justin Posted February 17, 2008 Share Posted February 17, 2008 getting a new switch off ebay, cos mate said it could be the switch.. though on way home this evening, tried dipped headlights and they worked! most odd.. So its an intermittant problem now.. great! lol! Reckon i ought to swop the indicator switch and the relay and hope that will fix it? Or just the switch? Link to comment Share on other sites More sharing options...
Guest SG1 Posted February 17, 2008 Share Posted February 17, 2008 (edited) Mate I had the exact same problem. With the lights on as you would for dipped (2nd turn of switch),push the relays a bit and see if they work. Did it for mine,and it worked but I had to keep doing it so I wedged a bit of paper in between the two and also between fusebox and outer realy,and they have been fine ever since. Want it sorted properly one day but at least it`s ok now. Edited February 17, 2008 by SG1 Link to comment Share on other sites More sharing options...
Guest Justin Posted February 17, 2008 Share Posted February 17, 2008 Mate I had the exact same problem. With the lights on as you would for dipped (2nd turn of switch),push the relays a bit and see if they work. Did it for mine,and it worked but I had to keep doing it so I wedged a bit of paper in between the two and also between fusebox and outer realy,and they have been fine ever since. Want it sorted properly one day but at least it`s ok now. relay in the engine bay? I checked the fuses in the fuse box. Both were fine and hadnt popped.. i guess a new relay would sort it? Link to comment Share on other sites More sharing options...
Guest SG1 Posted February 27, 2008 Share Posted February 27, 2008 Yeah mate,the white ones at the back of the fuse box. It`s a fair while after your last response so you may have sorted it now,but let us know whatever any. It`s always good to have the solution to the problem and may help someone else later on. Link to comment Share on other sites More sharing options...
Guest robman1 Posted February 27, 2008 Share Posted February 27, 2008 (edited) as above mate, white ones at the back. i had this exact problem for 4 months and it was the relay. switch the two relays round, one is full beam other is dipped. i only sorted mine last week lol Edited February 27, 2008 by robman1 Link to comment Share on other sites More sharing options...
Guest Justin Posted February 27, 2008 Share Posted February 27, 2008 as above mate, white ones at the back. i had this exact problem for 4 months and it was the relay. switch the two relays round, one is full beam other is dipped. i only sorted mine last week lol Yeah, intermittant problem.. Im hopeful of sorting it soon! Havent had a problem the last week or so... lights have been working when i need them to be and havent had a chance to sort it! Hopefully will do this weekend! Link to comment Share on other sites More sharing options...
Guest robman1 Posted February 27, 2008 Share Posted February 27, 2008 yeh i didnt change the relay, just switched the two over, and both dipped and main work perfect. Link to comment Share on other sites More sharing options...
