Guest SG1 Posted February 10, 2008 Share Posted February 10, 2008 As above,what`s involved and is it worth it `cos I may have gotten a heated one? Any help or advice is great,thanks guys. Steve. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted February 10, 2008 Share Posted February 10, 2008 really easy m8 (but dont ask cabbydaz!!! PMSL) push rubber seal from inside behind the lip all the way around & window should come out (screwdriver) remove clock/light & you should have a contact point there & 1 either side of the window, push cord in right around the seal (1st/deepest groove) & overlap it @ the bottom of the window, then pull cord & rubber will come back over the frame (a little pressure on the window screen) when all in bang along seal from outside for snug fit - JOB DONE Link to comment Share on other sites More sharing options...
Guest SG1 Posted February 10, 2008 Share Posted February 10, 2008 Cheers big boy Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted February 11, 2008 Share Posted February 11, 2008 If your fully comp on your insurance you can get a new one fitted for around £120 - £150 !!! Link to comment Share on other sites More sharing options...
Guest no2lurch Posted February 12, 2008 Share Posted February 12, 2008 windscreen excess is only about 60 quid. well mine was anyway! mine needs to come out after eatser do i can paint around it! Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted February 13, 2008 Share Posted February 13, 2008 (edited) Mine too Bud, got rust going under the rubber seal, and its heated !!! Edited February 13, 2008 by ESCORT-X4GC Link to comment Share on other sites More sharing options...
