Going Back To Standard Suspension
Guest no2lurch
Guest no2lurch
here is my car...
http://www.escortcabrioletclub.co.uk/forum...showtopic=11872
i dont know what suspension is on it, but the car feels every bump and pothole.
i a thinking about going back to standard suspension for a softer ride. (as to not wake a baby in it all the time). if i did go back to tandard suspension, would it make much difference?
Guest turbocabbie
money is why, and ease of doing it.
twist of a nut you say, but it aint exactly a 5 minute job is it?
that's very true, its not a five minute job.. if you want some standard suspension and springs I have some I can post to you.. you pay for courier to collect and they are yours, cant say fairer than that..... they are not worn or leaky... I can post pics if you want a look
They are standard RS shocks.. little firmer than standard but still jelly in a bowl
if you need anything else I can send that with the courier, make a list :tongue:
Guest no2lurch
leave it with me mate, and i'll get in touch. where are you? what would the kit consist of? just springs?
Guest turbocabbie
standard shocks and springs, they came off my car and I know they are good (ill get pix up the weekend).. they are yours if you want them
Guest turbocabbie
turbocabby - pm waiting for you.
Here they are standard shocks and springs, front shocks were painted blue to match my car....(got all four springs even though there are only 3 in the pic) ... not mint buffy standard, but they do not leak and were good on my car.
If you want them they are yours either we can meet up in London somewhere for a drink or you can pay a courier to collect them.... no sweat either way for me
Edited by turbocabbie
Guest no2lurch
i'll take them mate. get tem boxed up and weighed, and i'll arrange coolection.
can i ask a question...
for the fronts, do i just undo the top nut and bottom 2 bolts and they pull straight off? are the damper and spring one assembly?
for the backs, jack up the car and take the springs out seperate to the dampers? then top nut and bottom bolts?
Guest turbocabbie
You are correct in what you say, the backs can be entertaining to say the least to get off... have a nut splitter and some swear words to use at appropriate times
Guest no2lurch
the other thing is too, i presume i just swap the strut mounting components over? mine will fit yours wont they?
i have been looking into a nut splitter too, and i cant use one on the front top mounts. reason is because the nuts sit lower down than the strut tops.
