Guest no2lurch Posted January 27, 2008 Share Posted January 27, 2008 apart from the obvious cam upgrade, would there be any advantage in swapping the head on my 1800 zetec for a 2.0 head? i got a silver top 1800, and i can get a 2.0 head for about 50 quid with cams etc, and i was wondering is it possible, and more importantly, is it worth it? Link to comment Share on other sites More sharing options...
Guest cabbydaz Posted January 27, 2008 Share Posted January 27, 2008 apart from the obvious cam upgrade, would there be any advantage in swapping the head on my 1800 zetec for a 2.0 head? i got a silver top 1800, and i can get a 2.0 head for about 50 quid with cams etc, and i was wondering is it possible, and more importantly, is it worth it? iv herd it dont make much difference but depend wat cams u got on yours 105 115 130 136 like iv got the 130s 2.0 cams dont think there much more than this not 10% sure mate Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted January 28, 2008 Share Posted January 28, 2008 Like Daz said mate, if you have the 130 engine you only getting 6 BHP more and its not much for the money and effort, then again if you have the 105 or the 115 like me it well worth it !!! Link to comment Share on other sites More sharing options...
Guest no2lurch Posted January 28, 2008 Share Posted January 28, 2008 i got the 115 engine out of a gti, but i got the over the top type inlet cos the pastic gti inlet wont fit. Link to comment Share on other sites More sharing options...
Guest ajs_20 Posted January 29, 2008 Share Posted January 29, 2008 i wouldn't even bother doing a head swap it will probably kill the bottom end quite easily. just do the 2.0 Cams, throttle body and MAF sensor on yours and that will push it to 130 BHP. Or you could just use a 2.0 Mondeo engine as they are reliable and more torquey but if you do that make sure you get the gearbox with it. They are an MTX 75 which are 10 times better than the standard IB5 found in all other petrol Escorts! Link to comment Share on other sites More sharing options...
Guest no2lurch Posted January 30, 2008 Share Posted January 30, 2008 the thing is, i have a mk4 so the only gearbox i can use is the cvh one due to the others being too wide. also, i am using he efi cvh loom on the zetec so i dont have a maf sensor. the reason i went 1800 zetec was cos i thought it would be easier to convert as no need to change the sump, water pump etc. Link to comment Share on other sites More sharing options...
Guest thesavage83 Posted January 30, 2008 Share Posted January 30, 2008 ive got a 105 and got some cams 2day from a si 130 they look identicle and even have the same numbers on them do they need 2 be from a mondeo 2litre Link to comment Share on other sites More sharing options...
