Guest DUANE Posted January 21, 2008 Share Posted January 21, 2008 hi i have a 1.6 zetec efi i have read posts on changing m a f sensers and throttle body but was not sur what size engine it was on about so can u change them on the 1.6 and if so what ones will fit and does it make much differnce sorry if u keep getting these questions thanks for ur help in advance Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 21, 2008 Share Posted January 21, 2008 here is another pic i cant resize otherwise i would put more up more pics i paid £170 for this with out wheels it went straight through a test with no work at all so now its time to start doing it up Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 21, 2008 Share Posted January 21, 2008 not to sure if the bits from the 1.8 zetec and the 2.0 fir, i would assume that they do. you will not get much gain at all by doing this tho mate. best thing to do is get a induction kit and ditch the cat. that will see ya a bit more of a gain than the other bits failing that ya can drop a 2.0 in for not to much hassle Link to comment Share on other sites More sharing options...
Guest southern lass Posted January 21, 2008 Share Posted January 21, 2008 Lovely cab Duane, love the kit. Enjoy it! Lisa. Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 21, 2008 Share Posted January 21, 2008 well i got an induction kit on and will de cat it ive had the car since begining of nov but aint drove it i had to get me brov to test it as i cant walk at the moment i was in me m8s car when he crashed and i went through the windscreen (no belt on ) doing 70mph so i dont know what the engine is like or what to expect from it Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted January 21, 2008 Share Posted January 21, 2008 Love your Cab DUANE, looks COOL !!! I will be doing the following to my 1.8 in the future, not sure if you can do them but the following mods are good for power gains and can be done for less than £450 if you look for bargains on the likes of eBay !!! 1. K&N Fillter 2. Stainless back-box 3. De-Cat Pipe 4. 2.0 MAF Sensor 5. 2.0 Throttle Body 6. 4 Branch Manifold 7. Mondeo 2.0 136 BHP Cams 8. Better Plugs and Leads If you don't believe my prices, I got items 1, 2, 4 and 5 for £120 !!! Link to comment Share on other sites More sharing options...
Guest ajs_20 Posted January 24, 2008 Share Posted January 24, 2008 Induction kit waste of time please trust me on this if its the later Zetec with the 'upside down' inlet manifold then its a waste of time. The throttle body and MAF are pointless without the cams. Decat yes but be prepared to kill Lambda sensors and fuel! Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 25, 2008 Share Posted January 25, 2008 yep i can empty a tank in less than 200 miles, does go better tho Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 25, 2008 Share Posted January 25, 2008 so iam better off with a 2ltr mondeo engine is there much involved in doing this Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 25, 2008 Share Posted January 25, 2008 gota change the sump, oil pick up, flywheel, ecu, maff sensor all the bits can be nicked off ur 1.6 lump accept ecu and maff they will need to come off of the engine Link to comment Share on other sites More sharing options...
Guest ajs_20 Posted January 25, 2008 Share Posted January 25, 2008 yea i recommend this also. you get alot more torque as well as 40 bhp more power! if you were really minted for money i would really recommend an RS2000 motor but tbh its a bit extreme, a hell of a lot of work and the 2.0 zetecs are good engines. Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 25, 2008 Share Posted January 25, 2008 which wiring harness would i need to use dose the escort one fit the 2ltr ? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 25, 2008 Share Posted January 25, 2008 i think u use the escort loom and plug the ecu into that, ill find ya a link Link to comment Share on other sites More sharing options...
Guest markeyboy Posted January 25, 2008 Share Posted January 25, 2008 the engine swap bit -- -- -- -- clicky the ecu swap bit -- -- -- -- clicky Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted January 26, 2008 Share Posted January 26, 2008 Cheers for that mate, I have saved all that in my notepad for future reference, i'll see what you say once you have done it !!! Link to comment Share on other sites More sharing options...
