Guest tigertom Posted January 3, 2008 Share Posted January 3, 2008 New to the site - but here goes! My Mk5 1993 xr3i cabriolet suddenly cut out on me this summer. Having been recovered, my local mechanic tried to find the fault and ended up 'hotwiring' the fuel pump to make her fire. He was advised that the fuse box was at fault so I got a replacement from eBay and had it fitted but it made no difference. The battery was draining overnight and so my mechanic found a relay to do with the time delay on the interior lights that was causing the problem. the car started and ran fine but without the above working. this did not matter on a pracitcal basis but I want to get her back to good order. He got advice again and was told that the door lock control unit was at the root of all this. The coded is 91AG14A093 AB. My questions to all you knowledgeable folk: - does this sound right and will replacing the door control unit fix all the other problems? - would a unit coded 91AG14A093 CC work just as well? Thanks in advance! Link to comment Share on other sites More sharing options...
Guest DUANE Posted January 28, 2008 Share Posted January 28, 2008 try unpluging the door look unit put a new relay in the time delay leave it over night locking each door manually then leave it over night see if the bat is dead if not the door locking unit is at fault if it is ur fault is els ware hope u manage to sort it Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted January 28, 2008 Share Posted January 28, 2008 This kind of electical problem and part codes are not my specialty mate but there are other peeps like DUANE who can help you out !!! WELCOME TO THE CLUB !!! I hope you prop is sorted soon and you get the cab on the raod again soon !!! Link to comment Share on other sites More sharing options...
