Guest bigjon Posted December 6, 2007 Share Posted December 6, 2007 Hi im well and truly stuk on my turbo cab project , I put the engine in, tried to run my engine with ofac managment but had problems so i decieded to switch to ofab but the only thing holding me up is the wiring to the xr3i loom , i have tried many ways of connect it but nothing seems to work im not getting a spark from my coil pack, so the engine will not start. can anyone help me sort this problem out with a little info on connecting this feista ofab loom to my xr3i, like where is the best place to join the looms and what colour wires connect to each other. my engine is a efi cvh from a feista turbo. Link to comment Share on other sites More sharing options...
Guest catrick Posted December 6, 2007 Share Posted December 6, 2007 i thought frst have seperate engine loom and interior loom i could be wrong but if it is there is no need to join it to you existsing loom i will find out today for you as i have a frst that im breaking for the engine Link to comment Share on other sites More sharing options...
Guest catrick Posted December 6, 2007 Share Posted December 6, 2007 i thought frst have seperate engine loom and interior loom i could be wrong but if it is there is no need to join it to you existsing loom i will find out today for you as i have a frst that im breaking for the engine defo a seperate engine loom might need a few pin changes and when you swapped tle loom are you using the right ecu Link to comment Share on other sites More sharing options...
Guest bigjon Posted December 6, 2007 Share Posted December 6, 2007 defo a seperate engine loom might need a few pin changes and when you swapped tle loom are you using the right ecu yes mate using a ofab ecu and wiring loom just need to know the best place to join the loom to the car xr3i loom and if the colours match cheers mate Link to comment Share on other sites More sharing options...
Guest catrick Posted December 6, 2007 Share Posted December 6, 2007 yes mate using a ofab ecu and wiring loom just need to know the best place to join the loom to the car xr3i loom and if the colours match cheers mate i cant understand why you need to join it to the 3i loom best place to try os oddkidd creations some one on there will defo tell you matey Link to comment Share on other sites More sharing options...
Guest bigjon Posted December 6, 2007 Share Posted December 6, 2007 i cant understand why you need to join it to the 3i loom best place to try os oddkidd creations some one on there will defo tell you matey all i need to wire up is the fuel pump oil pressure light injection relay earth and rev counter live and inction live didnt think it would be this hard Link to comment Share on other sites More sharing options...
Guest catrick Posted December 6, 2007 Share Posted December 6, 2007 as aid matey try oddkidd creations will defo sort it for you Link to comment Share on other sites More sharing options...
