Windows And Seals
Guest Charley
Guest Charley
I cannot seem to solve the problem i have with my car leaking.
I have heightened the passenger window which was the only leak but it was causing big puddles in car, now when you shut the door you have to lower the window otherwise the door doesn't shut properly and the window sits on the outside of the seals (if that makes sense). When you do the window back up once the door has shut it won't go up fully (you can hear the motor go as the window hits the seals and stops).
Since this the driver side is now leaking and the passenger side isn't as bad as it was. The water is leaking from the curve on the window, water just dripping in.
I'm going crazy trying to stop the car leaking and need some help :help: :help: :help:
My windows are manual but I had a similar problem, if i closed the door by pushing the door to close it, oppose to pushing the door shut with the glass, the window didnt sit between the roof and the seal.
try closing the door by pushing on the glass, if it doesnt go under its too high. otherwise as a pain in the arse quick fix close the door from inside, lower and then raise the window and get out the passenger side (opposite if its passnger side leaking lol)
Guest Charley
It's the passenger side that you can't shut door properly on. it still leaks though when done up
It's really frustrating and i want to cry :icon_cry:
Guest Charley
I'm trying to get my family to let me park it on the drive just need to get some wood or something for underneath for the leak and then find something quick and easy to put on and off
aaaaaaawwwww charley....dont get upset mate....take some piccies...has the door dropped? how are the lines from back and side of the car?
Uncle charlzeys coming down in 2 week, but get some pics up of how the door and window looks. XX
