Guest garyg2407 Posted November 13, 2007 Share Posted November 13, 2007 hi I'm getting a new starter motor to day the problem is i don't now which one to get my car is a freg mk4 1.6 xr3i which voltage do i get is it the 0.8 or the 1.4 vols thax for eny help Link to comment Share on other sites More sharing options...
Guest Eggsy Posted November 13, 2007 Share Posted November 13, 2007 can you not get the part number from the last starter ?? Link to comment Share on other sites More sharing options...
Guest garyg2407 Posted November 13, 2007 Share Posted November 13, 2007 no m8ty its not on it Link to comment Share on other sites More sharing options...
Guest sjc Posted November 13, 2007 Share Posted November 13, 2007 (edited) do you mean kW...the bosch starter motor was 0.8kW Copied from haynes: Starter motor Type . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Pre-engaged Make: Bosch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.8 kW, 0.85 kW, 0.9 kW, 0.95 kW Lucas . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8M 90, 9M 90, M 79 Nippondenso . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 0.6 kW, 0.9 kW Minimum brush length: Bosch . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0 mm Lucas . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 8.0 mm Nippondenso 0.6 kW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 10.0 mm Nippondenso 0.9 kW . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 9.0 mm Edited November 13, 2007 by sjc Link to comment Share on other sites More sharing options...
