Guest karltisot Posted October 28, 2007 Share Posted October 28, 2007 HI ALL, my cab leaks into the drivers side front and rear footwells, i found the problem, the drivers door seal (these are 2 piece seals) the water runs down the seal from the roof seal above the windscreen and gets near the bottom corner and runs over the top of the seal a gathers long the top and runs down the inside of the seal and down in to the footwells, does someone know if the front seal is the same as a tintop door seal (i know the rear part is diffrent as it has a padded section on it) are thay still availble from fords? all info will be a great help REGARDS KARL Link to comment Share on other sites More sharing options...
Guest talisman Posted December 10, 2007 Share Posted December 10, 2007 HI ALL, my cab leaks into the drivers side front and rear footwells, i found the problem, the drivers door seal (these are 2 piece seals) the water runs down the seal from the roof seal above the windscreen and gets near the bottom corner and runs over the top of the seal a gathers long the top and runs down the inside of the seal and down in to the footwells, does someone know if the front seal is the same as a tintop door seal (i know the rear part is diffrent as it has a padded section on it) are thay still availble from fords? all info will be a great help REGARDS KARL I had this problem, use a little sealer on the insode of the seals where they join. This prevents them from becoming a channel for water. If you do this while the roof is half down you can plug up all of the edges of the seals and let them dry so they dont stick together. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted December 10, 2007 Share Posted December 10, 2007 if its roof seals you need I have a couple of sets here ?? Link to comment Share on other sites More sharing options...
