Guest pete soulby Posted September 12, 2007 Share Posted September 12, 2007 How does the rear cable that goes around the bottom of the roof secure itself to the car? I'm talking about the one thats similar to bike brake cable with a threaded bar on each end. Pete Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 12, 2007 Share Posted September 12, 2007 it goes back into the car by the rear window each side, there is a threaded stud on the end of the cable which passes through a little bracket (has to holes for more tightness) and ya stick a nut on the end, you have to take the speaker pod pannel off to get at these Link to comment Share on other sites More sharing options...
Guest pete soulby Posted September 12, 2007 Share Posted September 12, 2007 it goes back into the car by the rear window each side, there is a threaded stud on the end of the cable which passes through a little bracket (has to holes for more tightness) and ya stick a nut on the end, you have to take the speaker pod pannel off to get at these # cheers markyboy, found them today whilst looking a little deeper. Link to comment Share on other sites More sharing options...
