Guest matt-the-dj Posted September 11, 2007 Share Posted September 11, 2007 i have a 93 k 1.4 dash with i believe has a 1.4 cvh (i think ) engine which has the large style air intake which picks up a hot feed of the manifold, can i fit an aftermarket induction kit?? if so any ideas where?. any suggestions which exhaust i could fit to make it a bit more meaty. :convertible_mazeguy: Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 11, 2007 Share Posted September 11, 2007 for your induction you can fit a k&n sandwich filter which bolts onto the top of the carb. for an exhaust there are so many to choose from, have a look on pton.com, thqats where mine came from Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 12, 2007 Share Posted September 12, 2007 for your induction you can fit a k&n sandwich filter which bolts onto the top of the carb. for an exhaust there are so many to choose from, have a look on pton.com, thqats where mine came from does that filter completely replace the plastic housing, what happens to the warm air inlet and the little wax valve which lets in the cold air? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted September 12, 2007 Share Posted September 12, 2007 yes mate it replaces the lot, i think that bit gets forgotten about Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 12, 2007 Share Posted September 12, 2007 yes mate it replaces the lot, i think that bit gets forgotten about any idea where i can get more info ,do you have model no's etc cheers for the info, i had an old mk2 estate escort and bits of info for that are slowly coming back to me. Link to comment Share on other sites More sharing options...
Guest matt-the-dj Posted September 12, 2007 Share Posted September 12, 2007 any idea where i can get more info ,do you have model no's etccheers for the info, i had an old mk2 estate escort and bits of info for that are slowly coming back to me. found a website that sells em £54 quid not sure if i need other bits and what bits get binned. :convertible_mazeguy: Link to comment Share on other sites More sharing options...
