Guest rs_turbo_ant Posted September 7, 2007 Share Posted September 7, 2007 how is the ford badge held on 2 the boot on a mk4 xr3i cab is it just like double sided tape or does it go in 2 the boot with sticks (get me)....and wots the best way 2 take it off just rip it of or is there ne thing 2 ease it off thank much :help: Link to comment Share on other sites More sharing options...
Guest mick_borthwick Posted September 7, 2007 Share Posted September 7, 2007 how is the ford badge held on 2 the boot on a mk4 xr3i cab is it just like double sided tape or does it go in 2 the boot with sticks (get me)....and wots the best way 2 take it off just rip it of or is there ne thing 2 ease it off thank much :help: using a small screwdriver will damage both the badge and the panel,,so thats a no no..best way i think is to use thin fishing wire or alike to work the badge off, by putting the nylon wire behind working up and down slowly..if you get my drift. this will cut through the foam rubber type adisive on the back of the badge, then remove the left behind residue with a hair drier. hope this helps. mick Link to comment Share on other sites More sharing options...
Guest Tim64cars Posted September 8, 2007 Share Posted September 8, 2007 using a small screwdriver will damage both the badge and the panel,,so thats a no no..best way i think is to use thin fishing wire or alike to work the badge off, by putting the nylon wire behind working up and down slowly..if you get my drift. this will cut through the foam rubber type adisive on the back of the badge, then remove the left behind residue with a hair drier. hope this helps. mick he means something like dental floss Link to comment Share on other sites More sharing options...
Guest fatboy billy Posted September 8, 2007 Share Posted September 8, 2007 or just put aahirdryer on it that will heat it up and make the double sided soft and wil lcome off easy Link to comment Share on other sites More sharing options...
Guest Eggsy Posted September 8, 2007 Share Posted September 8, 2007 just use an old bank card or something m8 :icon_salut_gb: then pick the rest off & polish Link to comment Share on other sites More sharing options...
Guest rs_turbo_ant Posted September 10, 2007 Share Posted September 10, 2007 cheers ill try all of them Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted September 19, 2007 Share Posted September 19, 2007 Once you get it off there might be a little bit left over, use methylated spirt or Turtle Wax Tar remover !!! Link to comment Share on other sites More sharing options...
