Guest westy Posted August 15, 2007 Share Posted August 15, 2007 hi every1 just after a bit of help! ive got a leak problem with mi mk4. i went to the car on mi lunch and found a nice big puddle on the drivers seat!! i fink tht it is cumin from the top of the door/glass were it meets the roof. i also noticed tht the windo does sit properly on the roof seal n was wondering is ther any way in which i can get the windo to sit in ther properly! ive tried lettin the windo down abit but the it leaves a gap between the roof and the windo. please help i dont like swimmin and drivin at the same time!!!! cheers Link to comment Share on other sites More sharing options...
Guest mick_borthwick Posted August 15, 2007 Share Posted August 15, 2007 take off your door card mate and see if you adjust up your window regulator higher within the door..thus raising the glass higher Link to comment Share on other sites More sharing options...
Guest westy Posted August 17, 2007 Share Posted August 17, 2007 its not tht i dnt fink coz its high enough its tht i cant get the windo under the little lip thts on the roof seal at the top of the door, any other ideas??? but il double check the windo hight n see if it makes any difference cheers Link to comment Share on other sites More sharing options...
Guest Eggsy Posted August 17, 2007 Share Posted August 17, 2007 i think i've read an article in the roof section about this westy, some1 had the same problem, but sorted it somehow - cant remember exactly though?? Link to comment Share on other sites More sharing options...
Guest Eggsy Posted August 17, 2007 Share Posted August 17, 2007 hi every1 just after a bit of help! ive got a leak problem with mi mk4. i went to the car on mi lunch and found a nice big puddle on the drivers seat!! i fink tht it is cumin from the top of the door/glass were it meets the roof. i also noticed tht the windo does sit properly on the roof seal n was wondering is ther any way in which i can get the windo to sit in ther properly! ive tried lettin the windo down abit but the it leaves a gap between the roof and the windo. please help i dont like swimmin and drivin at the same time!!!! cheers FOUND IT WESTY http://www.escortcabrioletclub.co.uk/forums/index.php?showtopic=7567 Link to comment Share on other sites More sharing options...
Guest Eggsy Posted August 17, 2007 Share Posted August 17, 2007 FOUND IT WESTY http://www.escortcabrioletclub.co.uk/forums/index.php?showtopic=7567 if that link dont work its on p3 of roof problems (at the mo) topic starter is BRETT Link to comment Share on other sites More sharing options...
Guest westy Posted August 18, 2007 Share Posted August 18, 2007 cheers mate. link didnt work so il ave a quik look on the roof problems cheers again opefully it will help dnt llok like thers gna b any more sun this year cheers. Link to comment Share on other sites More sharing options...
