Mk 4 Roof Leaking!!??!!
Guest westy
hi every1 just after a bit of help! ive got a leak problem with mi mk4. i went to the car on mi lunch and found a nice big puddle on the drivers seat!! i fink tht it is cumin from the top of the door/glass were it meets the roof. i also noticed tht the windo does sit properly on the roof seal n was wondering is ther any way in which i can get the windo to sit in ther properly! ive tried lettin the windo down abit but the it leaves a gap between the roof and the windo. please help i dont like swimmin and drivin at the same time!!!! cheers
Guest mick_borthwick
take off your door card mate and see if you adjust up your window regulator higher within the door..thus raising the glass higher
its not tht i dnt fink coz its high enough its tht i cant get the windo under the little lip thts on the roof seal at the top of the door, any other ideas??? but il double check the windo hight n see if it makes any difference cheers
i think i've read an article in the roof section about this westy, some1 had the same problem, but sorted it somehow - cant remember exactly though??
FOUND IT WESTY
http://www.escortcabrioletclub.co.uk/forums/index.php?showtopic=7567
cheers mate. link didnt work so il ave a quik look on the roof problems cheers again opefully it will help dnt llok like thers gna b any more sun this year cheers.
