Guest russ1985 Posted August 6, 2007 Share Posted August 6, 2007 Hi everyone, :big_wave: Hope everyone had a wicked time at ford fair if you went, Sadly i coulnt make it due to family problems. Anyways, Ive just finished my mk4 turbo project an its got its mot on fri (Bring on sat Nite!!!) an i seem to have two small problems: 1)Washer pump does not work, ive taken it off an wired it straight to the battery an its fine, ive tried looked for fuse but there doesnt seem to be one for the pump, is there a relay somewhere? or is there a way of testing the switch? 2)Fuel Gauge is fine when car is idleing but when you rev the engine the gauge goes all the way up, let it idle and it reads correctly, then when i put my foot on the brake the gauge then goes all the way down to zero. I thought this may be the sender unit, but this all happens when the car is standing still!!! Cheers peeps Russell Link to comment Share on other sites More sharing options...
Guest massive Moooooo Posted August 6, 2007 Share Posted August 6, 2007 not to sure about the pump but the fuel sounds like bad connection so when you rev it its bridging ill have a think bout the pump :icon_salut_gb: Link to comment Share on other sites More sharing options...
Guest sjc Posted August 7, 2007 Share Posted August 7, 2007 i think (hope) all cabs are wired as mk3 cos they changed everthing in 88 for rear wash wipes whcih obviously dont apply. if they didnt change the wiring, or yours is pre 88, it is switched on the earth side so to test the switch in situ earth the Bk wire at the pump, this will short out the switch. the drawing shows the pump fed from fuse 2?? atb mick oh, if it is earth it may fix your clock problem as it sounds like you have some back feed from other circuits Link to comment Share on other sites More sharing options...
Guest russ1985 Posted August 7, 2007 Share Posted August 7, 2007 Cheers Mick, Very helpful, I'll Let you know how i get on. Russell Link to comment Share on other sites More sharing options...
