Guest stokie_babe Posted July 28, 2007 Share Posted July 28, 2007 hi, has anyone ever had this problem when i brought the car it wasnt there but its just got worse and worse now. when its cold and only when cold the light flashes on the dash but as soon it is warm it stops! but ive also noticed, not sure if its related but when i accelerate it stays on and when i let off the light goes off ! strange?? any help?? Link to comment Share on other sites More sharing options...
Guest markeyboy Posted July 28, 2007 Share Posted July 28, 2007 maby a loose connection where te air bag plugs in at the steering wheel Link to comment Share on other sites More sharing options...
Guest robman1 Posted July 28, 2007 Share Posted July 28, 2007 found out the wire was chewed in mine for some reason made it stay on constant. Link to comment Share on other sites More sharing options...
Guest stokie_babe Posted July 29, 2007 Share Posted July 29, 2007 i havnt got an air bag im also not sure where its wired to as this is part of my problem its the ABS light seems to be on when hot and cold now... really annoying as it flickers and makes a flickering noise aswell as if the relay is flickering off n on. Link to comment Share on other sites More sharing options...
Guest PIP Posted July 29, 2007 Share Posted July 29, 2007 top the tank up Link to comment Share on other sites More sharing options...
Escort Cabriolet Club Posted July 29, 2007 Share Posted July 29, 2007 Take the bulb out !!! Link to comment Share on other sites More sharing options...
Guest sjc Posted July 31, 2007 Share Posted July 31, 2007 hiya stokie babe....the light could be doing its job and telling you youve got a slack belt in one of your abs modualtors, they have a switch on that monitors the belt inside, best to get a haynes and look at braking chapter, theyve got pictures there or this link will take you stright there http://wheels.vc.org.ua/petrunko/escort/0686-09.pdf hopefully :big_wave: Link to comment Share on other sites More sharing options...
Guest massive Moooooo Posted July 31, 2007 Share Posted July 31, 2007 Top the fluid level first if its only just level with the min mark this can course it be on for couple of mins then go out this would also course it to come on during acceleratoin as the fluid moves back from the sensor so light goes on this should also happen under braking to once youve ruled that out it could be the belt tensioner sensor that is a little lose not a hard prob to fix but a little aqward to get to while checking these try the tension of the belts as one may very well be slipping hence the problem accelerating its usually one of these if you unable to check tension jus take it to a local garage that youve used regulary in the past and they check it and not lie and rip you off hpe thats of some help :icon_salut_gb: Link to comment Share on other sites More sharing options...
Guest sjc Posted August 1, 2007 Share Posted August 1, 2007 hiya moooo, aint got abs on mine but i thought the brake and abs had different warning lights. stokie babe, hope i aint misled you, if its not the fluid we both agree were to look next anyway x Link to comment Share on other sites More sharing options...
