Guest lll Posted April 23, 2017 Share Posted April 23, 2017 XR3i Mk4 used reguarly. Have lost reverse gear suddenly. other gears perfect. checked Linkage bolt joining G Box is tight. Any suggestions to fix Tks Quote Link to comment Share on other sites More sharing options...
RScab Posted April 23, 2017 Share Posted April 23, 2017 Need more info m8 Does the gearstick go onto the reverse position? The gearstick selector shaft may have moved on the gearbox shaft - does it feel different from normal? are there any noise's when attempting to select the gear? Quote Link to comment Share on other sites More sharing options...
