Guest Tony Walter Posted April 22, 2014 Share Posted April 22, 2014 Ludicrous , it locks ok but I have to juggle the key 15-20 minuets to make it open, of course one day it won't open. Eternally grateful for any advice 🚕 Thanks. Quote Link to comment Share on other sites More sharing options...
Guest Tony Walter Posted April 22, 2014 Share Posted April 22, 2014 Sorry, 1995 XR3i cab. Thankful for any ideas ? Quote Link to comment Share on other sites More sharing options...
gingergman Posted April 22, 2014 Share Posted April 22, 2014 hi mate, id take the door card off and have a look in the door, check the rod hasnt come of its clip going to the lock, while your there pull and push the rod to the central locking motor and see if it operates alright. Â does it unlock ok from the passinger side? if its the lock thats worn you can change over the one from the passinger side, you just need to remove a cir-clip and swap the back part around. Â hope this helps mate. Quote Link to comment Share on other sites More sharing options...
Guest XxpeteyxX Posted April 22, 2014 Share Posted April 22, 2014 i had this problem with my ignition i ended up having to replace it Quote Link to comment Share on other sites More sharing options...
Guest Tony Walter Posted July 14, 2014 Share Posted July 14, 2014 Thanks Ginger Boy Quote Link to comment Share on other sites More sharing options...
