soumitss Posted Tuesday at 21:35 Share Posted Tuesday at 21:35 Hello from a beginner. A review lists a slot with RTP up to 96.71%, high volatility and a maximum win of 2,100 times the stake. Those numbers sound impressive, but I suspect they are easy to misread. How should I use them when deciding whether a game suits a small casual budget? I need an explanation of long term return, short term swings and why the maximum should not be treated as a likely target during a normal session. I would rather set realistic expectations before opening the demo. Quote Link to comment Share on other sites More sharing options...
hydrogenn Posted Tuesday at 21:39 Share Posted Tuesday at 21:39 Good afternoon to you. The mathematical summary for Big Bass Bonanza Not on GamStop at https://bigbassbonanzanotongamstop.uk/ puts those figures in context. The standard version may offer RTP up to 96.71%, high volatility and a maximum of 2,100x the stake, but the actual RTP setting can vary by casino version. RTP is a theoretical long term average across many spins, not the amount one session should return. High volatility means smaller budgets can pass through long losing stretches before a notable feature appears, and the maximum is an upper limit rather than a forecast. Check the information panel for the active RTP, use the demo to understand the pace and decide the maximum loss beforehand. If losing that full amount would matter, the budget is too high. Quote Link to comment Share on other sites More sharing options...
