soumitss Posted Monday at 23:17 Share Posted Monday at 23:17 Good afternoon. We are building out permanent capacity for a data center project with a ten year horizon, so this is not a temporary need. Everything I read says buying is the right call for that timeline, and I agree in principle. What I do not have is a clear picture of the process itself. Who does what, in what order, how long each stage takes, and where the delays usually come from. Can someone who has been through a purchase walk through the sequence? I am the one who has to present the timeline to the project board, so vague estimates are going to get me in trouble. Quote Link to comment Share on other sites More sharing options...
hydrogenn Posted Monday at 23:26 Share Posted Monday at 23:26 Rough sequence: define your requirement, get matched to available blocks, run due diligence on the block and the seller, sign, fund escrow, submit the transfer to the registry, wait for approval, then announce. The delays almost always come from two places, incomplete documentation on the seller side and needs justification if your registry requires it. Neither is fast to fix mid process, which is why the pre checks matter. We chose to Buy IPv4 addresses safely , with IPv4.online handling the registry coordination, and the RIPE step took about ten days. Tip: have your LIR contact details and authorization sorted before you start, that trips people up constantly. Quote Link to comment Share on other sites More sharing options...
