Guest geordieimport Posted October 24, 2009 Share Posted October 24, 2009 Hi Guys, it`s the new boy here. Just bought a MK5 and drove it from Cambridge to Dudley, On the way the temp gauge went high a few times so let it cool and it was okay for a while then about 3 repeats Worse still dreaded power loss, intermitant then more persistant eventually ended up crawling along. When I picked the car up the fuel was very low so my guess is that the sludge at the bottom of the tank has been picked up and blocked the fuel filter. Any idea please? Thanks Alan Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted October 24, 2009 Share Posted October 24, 2009 (edited) did you check oil and water level? the thermostat might be sticking or head gasket might bown Edited October 24, 2009 by shaun Quote Link to comment Share on other sites More sharing options...
Guest geordieimport Posted November 1, 2009 Share Posted November 1, 2009 did you check oil and water level? the thermostat might be sticking or head gasket might bown Hi Shaun, oil & water seems okay, I`ve bought a fuel filter as the car won`t start at all now fuel starvation I guess. Just gotta get someone to fit it now, any ideas Quote Link to comment Share on other sites More sharing options...
