Guest adamk Posted December 23, 2008 Share Posted December 23, 2008 Hi, Im having a problem with my hardtop xr3i. The brakes are rock hard. i just tought thats how they are as the car is so old. and i hadnt driving the Cab in so long. But today i tuck out my cab, After its been parked up since the summer, and low and behold the brakes were perfict. My hard top brakes, you have to press the pedal really hard to get stoping power. Could this me the master cylinder or the Servo. or the vacume hose? I dont whant to go buying loads of part, to find its something simple. I need to sort it, as i have an MOT in jan. Thanks Chaps Link to comment Share on other sites More sharing options...
Guest cossi Posted December 24, 2008 Share Posted December 24, 2008 It will either be the servo or the vacuum pipe going to it. Hope you get it sorted. Link to comment Share on other sites More sharing options...
Guest adamk Posted December 24, 2008 Share Posted December 24, 2008 It will either be the servo or the vacuum pipe going to it. Hope you get it sorted. Cheers il give that a go. I might wip the vacum pipe of the cab, and see if that helps. then il know what part to go lookin for. Link to comment Share on other sites More sharing options...
