Guest cotter1982 Posted April 29, 2008 Share Posted April 29, 2008 hi just wondering if any of you guys can help with my roof problem, got my self a mk4 rs turbo cabriolet but when i got it the boy had converted it to power hood but needed the relays and switch, so got them now and roof goes down but wont come up by switch but works manually no problem, can any 1 help please thanx cotter Link to comment Share on other sites More sharing options...
Guest markeyboy Posted April 29, 2008 Share Posted April 29, 2008 swap the relays around and see what happpens, may be a dead one Link to comment Share on other sites More sharing options...
Guest cotter1982 Posted April 29, 2008 Share Posted April 29, 2008 (edited) ive tried that already was still the same, cheers pal, relays were bought new from ford the other day Edited April 29, 2008 by cotter1982 Link to comment Share on other sites More sharing options...
Guest badgerdid Posted April 30, 2008 Share Posted April 30, 2008 Sounds like it could be the switch or the wiring from one side, up side. Link to comment Share on other sites More sharing options...
Guest Eggsy Posted April 30, 2008 Share Posted April 30, 2008 It may sound daft but have you checked the fluid levels?? Link to comment Share on other sites More sharing options...
f40 cab Posted April 30, 2008 Share Posted April 30, 2008 ok like said in other posts check fluid level in pump, i think it needs to be checked when roof is open. then check wiring to the switch them switches can be a pain not all connectors used on them so maybe a wire on wrong one. relays new bet that was expensive heated front screen relay £26. Link to comment Share on other sites More sharing options...
Guest sjc Posted April 30, 2008 Share Posted April 30, 2008 ok like said in other posts check fluid level in pump, i think it needs to be checked when roof is open. then check wiring to the switch them switches can be a pain not all connectors used on them so maybe a wire on wrong one. relays new bet that was expensive heated front screen relay £26. thought I had read this one before...didnt someone post a drawing as well..... one relay for up and one for down....see if the up relay is clicking when you do the switch then you will know where to look next. Link to comment Share on other sites More sharing options...
Guest DJB29 Posted April 30, 2008 Share Posted April 30, 2008 heres how i wired my conversion works perfect pin 30 to the pump pins 85 and 87a to ground pin 87 to +12v(permanent live I believe) pin 86 to the switch. both relays are wired the same way, one makes it go up and one down which does what will depend on how you connect it at the pump end so if the switch sends it the wrong way swap those connections over. Don't forget to use fuses in the 12v feeds. 30amp to the pump and 15amp to the switch theres a diagram of this setup under useful cabrio information(power roof conversion) Link to comment Share on other sites More sharing options...
Guest cotter1982 Posted May 8, 2008 Share Posted May 8, 2008 will get the wiring checked, its my first cabby so dont really know much about them, how do you check the fluid? F40 cab the relys were only £12.50 each from ford, Link to comment Share on other sites More sharing options...
