Fans For Stronger Stems
Gentle airflow across seedlings from day one thickens the stem, and on an auto that matters because a thin stem will flop under the cola weight in week seven. The fan should move the leaves, not thrash them, and it needs to reach the lower part of the plant rather than just the top. Airflow placement diagrams for small tents are on https://turboautoflowerseeds.com, which is where I saw the advice to point the fan at the wall instead of at the plant. Staking later is a poor substitute.
