Legovglas Posted 2 hours ago Share Posted 2 hours ago (edited) I lost around 400 dollars worth of skins in my first year of trading. Not to scammers exactly, just to my own laziness and overconfidence. I would eyeball a price, think "yeah that looks about right," and either buy something overpriced or sell something underpriced because I could not be bothered to do ten minutes of research first. I thought I had a feel for the market. I did not. Nobody does when they are starting out, and honestly even experienced traders get burned when they get sloppy. That frustration sat with me for a long time, and it is the reason I now treat every single trade like a small business transaction rather than a casual handshake. So here is what I actually do now, and why I think it matters. Stop trusting your gut on pricing The first thing I changed was accepting that my instinct on skin value is basically worthless without data behind it. Skins shift in price constantly. A knife that was worth 180 dollars three weeks ago might be sitting at 155 now because a popular player switched loadouts or a case came back into rotation. If you are not checking current values before every meaningful trade, you are gambling, not trading. I started spending time in places where other traders actually talk about this stuff openly. The csgo reddit community has been genuinely useful for that. Real people posting real questions, not just hype or flexing. You can search for a specific skin and usually find someone who bought or sold it recently, which gives you a grounded reference point rather than a stale listing somewhere. The float thing is not optional This took me embarrassingly long to take seriously. I used to think float was mostly for collectors obsessing over 0.001 differences on a Karambit. That is partially true, but float affects value in ways that matter even on mid-tier skins. A Battle-Scarred AK with a bad float can be worth noticeably less than one with a float near the low end of that wear range. And on Factory New skins, a float of 0.003 versus 0.007 can swing the price by a meaningful amount if you are dealing in volume. If you do not know how to check skin float cs2 properly, you are leaving information on the table. I now check float on anything above about 30 dollars before agreeing to a trade. It takes two minutes and it has saved me from accepting bad deals multiple times. You start to build a sense of which float ranges actually matter for specific skins, and that knowledge compounds over time. My actual routine before a trade I keep it simple now. Before I agree to anything, I run through a short checklist: * Look up recent sold listings to get a real price, not an ask price. * Check the float and compare it to what is typical for that skin and wear. * Look at the pattern if it is a case-hardened or fade skin, since pattern index matters a lot on those. * Check the other person's trade history if I can. Not paranoid, just sensible. * Give myself a hard limit on how much I am willing to overpay for convenience. Usually zero. That last point is important. The "convenience premium" is how a lot of traders quietly bleed value. You are in a rush, the other person is being friendly, the skin is close enough in price, so you just do it. Do not. The market will have another copy of that skin tomorrow. Knowing what your own stuff is worth This sounds obvious but a lot of people genuinely do not know the current value of their own inventory. They have a rough number in their head from when they bought something months ago and they treat that as gospel. Prices move. Conditions change. Before you go into any negotiation, you should check steam inventory value properly using current data, not memory. I do a rough inventory audit every couple of weeks. It takes maybe 20 minutes and it means I always know roughly what I am working with. More than once I have realized something appreciated significantly and I had no idea, which changes how I approach trading it. The honest summary Trading carefully is not complicated. It is mostly just slowing down and doing the boring parts that impatient people skip. The traders who consistently come out ahead are not smarter, they are just more disciplined about the basics. Check the value. Check the float. Know your own inventory. Do not rush. That is genuinely most of it. Edited 2 hours ago by Legovglas Quote Link to comment Share on other sites More sharing options...
