Lewis Hale Posted April 22 Share Posted April 22 Are you a thrill-seeker? Do you enjoy the adrenaline rush of a good scare? Then buckle up, because we're diving headfirst into the terrifying world of Granny, a mobile horror game that has players screaming (and strategizing!) since its release. 1. What is Granny? Granny is a first-person survival horror game developed and published by DVloper, a Swedish indie game developer. Initially released on Android in November 2017 and later on iOS, Granny quickly gained immense popularity thanks to its simple yet deeply unsettling gameplay. The game puts you in the shoes of a helpless prisoner trapped in the creaky, dilapidated house of a terrifying Granny. Your mission? Escape before she catches you. Think of it as the world’s most terrifying escape room, with a permanent, axe-wielding resident. Sounds fun, right? 2. The Premise: A Nightmare Come to Life You wake up disoriented in a locked room. Sunlight struggles to pierce through boarded-up windows. A chilling silence hangs in the air, broken only by the distant creaks of the old house. Then, you hear it: the soft, shuffling footsteps of Granny. Granny is your captor, and she's not happy you're in her house. Armed with her trusty baseball bat (or sometimes something even more sinister!), she relentlessly patrols her home, listening for any sound that might betray your location. You have five days to find a way to escape, each failed attempt bringing you closer to a permanent stay in Granny's nightmarish abode. 3. How to Play: Survival 101 Okay, so you’re trapped. What now? Here’s a breakdown of how to play Granny and (hopefully) survive: Stealth is Your Best Friend: Granny has incredibly sensitive hearing. Dropping objects, knocking over furniture, even walking too loudly can alert her to your presence. Crouch to move silently and be mindful of your surroundings. Think of yourself as a ninja… a very, very scared ninja. Explore and Scavenge: Granny’s house is filled with useful items that can aid in your escape. Look for keys, tools, weapons, and other objects hidden in drawers, cupboards, and even in the most unexpected places. Every item has a purpose, so be sure to pick up everything you can find. Solve Puzzles: Escaping Granny's house isn't just about finding the exit; it's about solving a series of intricate puzzles. You'll need to use your wits and collected items to unlock doors, disable traps, and ultimately find your way to freedom. Expect to do some thinking (while simultaneously trying not to scream). Use Weapons Wisely: While you can't exactly "defeat" Granny, you can temporarily incapacitate her. Weapons like the shotgun, crossbow, and tranquilizer gun can stun her, giving you valuable time to progress. However, ammo is scarce, so use your shots carefully. Remember, she always comes back… Practice Makes Perfect (and Less Screaming): Granny can be incredibly challenging, especially at first. Don't be discouraged if you get caught frequently. Each playthrough is a learning experience. Pay attention to Granny's patrol patterns, the layout of the house, and the location of key items. The more you play, the better your chances of survival. 4. Useful Tips and Tricks to Outsmart Granny: Listen Carefully: Sound is crucial in Granny. Pay attention to Granny's footsteps, the creaking of doors, and any other audio cues that might indicate her location. Use headphones for an even more immersive (and terrifying) experience. Know the House: Memorizing the layout of Granny's house is essential. Learn the locations of key rooms, hiding spots, and escape routes. The better you know the house, the easier it will be to evade Granny. Utilize Hiding Spots: Granny's house is filled with closets, under beds, and other hiding spots. Use these to your advantage when Granny is nearby. However, don't get too comfortable – Granny will eventually check these spots! Be Patient: Rushing through Granny's house is a surefire way to get caught. Take your time, plan your moves carefully, and avoid making unnecessary noise. Distraction is Key: Throwing objects can create distractions that lure Granny away from your intended path. Use this tactic to your advantage when you need to slip past her unnoticed. Don't Forget the Safe: The safe contains valuable items that can aid in your escape. However, opening it requires finding a specific code. Be on the lookout for clues hidden throughout the house. Practice Mode: If you’re new to the game (or just really, really scared), consider starting in Practice Mode. This mode removes Granny, allowing you to explore the house and familiarize yourself with the layout and puzzles without the added pressure of being hunted. 5. Are You Brave Enough to Face Granny? So, do you think you have what it takes to outsmart Granny and escape her house of horrors? Play Granny today and test your courage! Let us know in the comments below what your scariest Granny experience has been. And remember… don't make a sound! Quote Link to comment Share on other sites More sharing options...
