Guest Springy2112 Posted September 29, 2018 Share Posted September 29, 2018 hi all my mk3 1.6 cabby just started to leak coolant inside the vehicle down by the clutch peddle seems yo be a bit damp with a drip at the bottom of thr heater box thers some screws that appear to hold a clear or opaque plastic section o to the heater box..it only drips after engine is stopped and lefy ovet night..heater is working fine..no overheating and coolant level not noticeably dropped...anyone had this issue before i start tearing it all apart? thanks in advance ...SpringyâŽâ¤ Quote Link to comment Share on other sites More sharing options...
Guest Paul Grainger Posted September 29, 2018 Share Posted September 29, 2018 Yup. Sounds like a leaking heater matrix. Time for a new one I am afraid. If you unbolt the heater box you can drop it down a bit and twist it a bit and the matrix will come out if you hold the clutch pedal down. Quote Link to comment Share on other sites More sharing options...
Guest Springy2112 Posted October 4, 2018 Share Posted October 4, 2018 On 29/09/2018 at 18:07, Paul Grainger said: Yup. Sounds like a leaking heater matrix. Time for a new one I am afraid. If you unbolt the heater box you can drop it down a bit and twist it a bit and the matrix will come out if you hold the clutch pedal down. ah thankyou , i had a little look in the haynes manual (which i should have done fisrt) and realised it a lot easier than i expected..then looked up prices and theyre a lot cheaper also !! bonus.. thanks for your reply i appreciate the help..cheers Springy Quote Link to comment Share on other sites More sharing options...
