Guest Rooyan Posted May 5, 2014 Share Posted May 5, 2014 Hi, i want to paint a few of my interior bits in my mk4 cab. just a few plastic bits and maybe the door handles (inside ) etc what paint is best to buy and should i use primer or not? any help would be great. Thanks Link to comment Share on other sites More sharing options...
Skittles80 Posted May 5, 2014 Share Posted May 5, 2014 You need to use a product called plastic adhesion promotor it is clear in colour then you primer then colour 9 out of 10 interior plastics never look right painted at home / DIY just take your time let me know how it geos the plastic adhesion promotor normally comes in a aerosol from a good trade moter factor good luck Link to comment Share on other sites More sharing options...
Guest Rooyan Posted May 5, 2014 Share Posted May 5, 2014 thank you mate, il let you know how it goes! Link to comment Share on other sites More sharing options...
Guest Rooyan Posted May 5, 2014 Share Posted May 5, 2014 is this what your on about? http://www.ebay.co.uk/itm/like/111331398261?limghlpsr=true&hlpv=2&ops=true&viphx=1&hlpht=true&lpid=108&device=c&adtype=pla&crdt=0&ff3=1&ff11=ICEP3.0.0&ff12=67&ff13=80&ff14=108&ff19=0 then just buy some colour spray? Link to comment Share on other sites More sharing options...
Skittles80 Posted May 7, 2014 Share Posted May 7, 2014 Yes it is spray light coat of this then primer rub down primer then spray colour before you start this job clean all plastics with white spirt removes silicones and any old dash gels/cleaners and use fine sand paper as course papers chew the plastics very easily good luck Link to comment Share on other sites More sharing options...
