Electric Roof?
Guest Stally08
Loom should just plug in m8
U may just need to unplug a connector behind the dash and plug in the roof loom then plug in the old connector
easy job
and yes that's looks like all the bits you need
i had a problem with my connectors, as my older G reg had them and my newer J reg didn't so i just run a live from my amp feed (from battery) straight to the pump and a live to the console switch from the back of my cd player (yellow wire i think going to switch)
Only problem is, is that you can open the roof whilst your driving which for obvious reasons is dangerouse unless your moving very very slowly :smile:
