I Want To Remove A Fuel Computer Sensor
gingergman
i striped out all the fuel computer gear from my cab, but the only part left is the sensor on the meetering unit, flow sensor i think? now i want to remove it but then im unsure of the red fuel pipes and where they would go, i know one stays on the sensor but what about the other? or does anyone have a pic of the set up?
Guest rapiernut
The should be 2 pipes going to the sensor you take the short one of with the sensor then you put the one you have left on to were the short one came off we done this last week with no problems hope this helps
Tried this this morning, when I looked at it it made sense, but the red pipe left isn't long enough! I'm guessing the pipe is different on models without the fuel computer fitted? It was made to fit before with bends etc, but now with that part removed its a no go!
  • 1 month later...
