Mot Revealed A Problem...
Guest 2steppa
Guest 2steppa
Just had my MK4 1990 cabby MOT'd (both drive shafts, and a wheel bearing mainly) but also the emissions were a pig to sort out. In the process the garage have told me that number 3 cylinder compression is low. My question is; what is the most likely reason, bore/rings or valves?
If it's bore/rings it's probably the end for the engine but if it's valve(s) is this an expensive job to get done?
Guest Alanman
Other than the garage telling you this information, how does the engine run? Does it smoke? Does it feel a bit flat and lifeless?
If neither, and you've managed to get it through the test okay I'd just keep running it until it starts causeing a problem.
Guest 2steppa
Hi Alanman...
It's a bit wheezy (130,000 miles) but still has 'enough' get up and go, doesn't smoke, does however need oil topping up every 7-8 weeks though mainly if it's had several high speed motorway journeys.
Guest Alanman
It most likely just need the head reconditioning, valve seat regrinding etc, but as said before I'd not be too bothered if its running nice.
Dont fix what's not broke. lol
Guest 2steppa
OK cheers. Just drove it home and to be honest it's a lot better since the injectors were cleaned etc still a slight miss now and then but that's to be expected. The pressure on number 3 is 80 PSI not sure what it should be though.
Oh well it is what it is at least it's ticketed up for another year and running ok.
