Guest paulige Posted February 17, 2013 Share Posted February 17, 2013 Hi everyone, i have just become a proud owner of my escort cabrio..1600cc. Its a R reg but its not running well. Its running high and low revs when its warm and smells like its running very rich when warm too. Im just hoping its not a serious problem. Can enyone advise me on what the reason could be for this please? Thanks. Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted February 18, 2013 Admin Share Posted February 18, 2013 ICV - Idle control valve ? Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 18, 2013 Share Posted February 18, 2013 That's what id also suggest, seems to be a common problem with the zetec engine Quote Link to comment Share on other sites More sharing options...
Guest Lee81 Posted February 18, 2013 Share Posted February 18, 2013 You definately have a idle control valve problem as mentioned but you may also have a a inlet manifold/MAF sensor problem. Fix the idle control valve by taking it off and cleaning with wkd 40. If you still have the problem get a new valve. Once thats sorted see how the car behaves. Diagnotics will pinpoint the other issues with sensor failure. These are common too and most cars I see have both problems. Quote Link to comment Share on other sites More sharing options...
Guest jimmy b Posted February 28, 2013 Share Posted February 28, 2013 hello & welcome..i also bought a mk 6 r reg 1.6 escort cabby recently fitted with the zetec li engine....& ive still got exactly the same problem..i replaced the maf..sensor..£35 e bay.@.driven automotive...& i also replaced the idle control valve..@£40.... same supplier..as it seemed to be the next logical step..this was done.. & fitted at around £93 inc labour & vat.k& n air filter & 4x new plugs....so total £180..now all was well..until today..it started on the key at 6 am from cold.. first turn..as usual..then it hunted 3 times..ie dropped to 250 rpm..then up to 850 rpm..brrm..brrm..brrm..with the rev counter dropping & rising..intermittingly..now in traffic it feels as if its going to stall & cut out....its very jerky ..on & off the throttle..kangerooing up the road.not good as its zinc yellow..lol.. .it also uses a lot of fuel..& the rear exhaust sports box is all sooted up ..a sure sign its over fuelling & running rich..it used to do this only when warm ..ie a 1/4 on the temp gauge...now its doing it constantly..but no issues with revs up to 5000 rpm..through the box.....its back at the garage..any ideas??..i love the car but its a pain in the rear end !! how good is the std ecu on this era of ford..will it store any faults??..& what reads it..is it adobe 1..ie first gen??..i wont shove any more money at it..alough a new throttle position sensor,o2 lamba sensor..or camshaft position sensor..is £70 for all three.. whats my next course of action???obviously i,l wait until the ecu has been read..if it can be....its mental.. Quote Link to comment Share on other sites More sharing options...
Guest jimmy b Posted April 28, 2013 Share Posted April 28, 2013 thought id post an update re my motor..now for the last 8 weeks the car is back to normal & running great....since the last post ..i also took the precautation of replacing the 90 degrees rear crankcase breather hose just as well..it was perished & colapsed..£15 at ford. still in supply..so inc this ive replaced pretty much all the possibble causes.. ..1.maf .2.icv.3 tps.4.crankcase breather pipe..deffo a real quick learning curve..but i think my cat is on the way out as im getting a smell of rotten eggs..il wait until mot time for the emmission test in nov.. Quote Link to comment Share on other sites More sharing options...
