Mk4 Cabby Efi Starting Problem.......pleeeeeeeeeese Help!!!!
Guest pimmy
Hi guys and gals I need a bit of help before I string myself up...lol
i've got a 1990 xr3i cabby which had a 1.4 lump in it when i bought it. I aquired a 1.6 EFI motor which i fitted this weekend but when i came to start it no joy. It turns over fine but just won't start but if i spray "easy start" in it will start and then run fine, it just wont start under its own steam and i'm baffled.
Any ideas will be greatly appreciated 'cos i'm stumped!!!!
cheers
paul
Guest s6boy1979
    1. Has to be a fuel issue. Undo the fuel pipe of the fuel rail and crank it over. I should come out with some serious force.
Has to be a fuel issue. Undo the fuel pipe of the fuel rail and crank it over. I should come out with some seriuos force.
Guest will_s1cab
id go with fuel pump relay 1st too, i found mine was not the relay but the fuse for the relay circuit. but do things methodically rather than just hacking at this and then that.
Thanks for the replies, turned out to be the EDIS 4 module. I jet washed my engine bay whilst the engine was out and must have knackered it then!! Luckily i had one that came with the engine, swapped it over and car started first time.....RESULT. :banana_dance:
Thanks again for the replies guys, helpful as always :salut_gb:
