Engine Has Stopped
Guest meaddy
hi, i've got a mk3 escort 1.6i cab its MFI it was running for about 20mins then stopped so i tried to start again and it didn't do anything. It doesn't even turnover just clicks, i have put another starter motor on it and that hasn't helped. I can hear a loud hissing noise coming from the rear of the engine would anyone know whats up with it. Thanks.
Sounds like you got a duff alternator or battery. Failing those that hissing noise could be an electrical short but you'd probably get smoke and burning smell also.
You need to charge the battery and get the car started.
Once started you need a multi-meter to keep to check voltage. should be be around 13.5v when running
  • 2 months later...
Guest PILLINJA
Its probably to late, as you posted your query 3 months ago. But all i do when that happens, is disconnect the - on the battery for about 30secs, reconnect n it always starts fine then after. The hissing sound is just your fuel pump, nothing to worry about, its a good sign!
