Suspension
Guest dancabs
Guest dancabs
Hi all. i wonder if anyone can help. i am running a mk4 xr3i on mondeo alloys with 195/45/r16 tyres. i wondered if any knows how much i can lower it on springs only so it doesn't rub the arches or rub on full lock. cheers for the help
40mm should be fine. You will however probably get rubbing on full lock even if you dont lower it.
Because the cab suspension is quite basic you can also add rings of 5mm metal plate underneath the springs in the lower wishbone arms to raise the rear end should you get problems. Just remember to silcone them in place so you dont get vibration/ rattles in them.
Guest dancabs
Cheers lee. the wheels and tyres are alraeady on with no rubbing on full lock..... so far so good. may go fo 30mm drop to be on the safe side.
