Guest Tatty Taylor Posted June 12, 2012 Share Posted June 12, 2012 Greetings... My 1.8 zetec 1997 cab has quite recently developed an annoying problem ,which is when i change up or down the gears the revs take a couple of seconds to drop off which makes smooth gear changing near on impossible. No other major issues. Car ticks over fine at idle.Any advice would be welcome as it is starting to annoy me as it sounds as though i am doing dodgy gear changes(i"m not honestly). Tatty.... Quote Link to comment Share on other sites More sharing options...
Guest kevsbluecab Posted June 13, 2012 Share Posted June 13, 2012 Hi fella I had exactly the same issue, it is a sensor on the gearbox to help with the idle. Te car doesn't really need it to be honest. I have disconnected mine which has solved the problem although sometimes it stalls at roundabouts etc but it's better than revving its nuts off when changing gear. To unplug the sensor there is a multi plug on the right had side of the engine at the back. It's too the right of the inlet manifold. It's a black plug. Unplug this and it should sort it. Although as I say it may stall sometimes. Let me know if you need me to to give a better description as il pop my bonnet and give more details, I think the culprit is called a speed sensor. Cheers Quote Link to comment Share on other sites More sharing options...
Guest Tatty Taylor Posted June 13, 2012 Share Posted June 13, 2012 Hi fella I had exactly the same issue, it is a sensor on the gearbox to help with the idle. Te car doesn't really need it to be honest. I have disconnected mine which has solved the problem although sometimes it stalls at roundabouts etc but it's better than revving its nuts off when changing gear. To unplug the sensor there is a multi plug on the right had side of the engine at the back. It's too the right of the inlet manifold. It's a black plug. Unplug this and it should sort it. Although as I say it may stall sometimes. Let me know if you need me to to give a better description as il pop my bonnet and give more details, I think the culprit is called a speed sensor. Cheers Thanks for that, i will give it a go and see what happens!! If you can give me a picture that would help. Can i get to it from under the bonnet?Cheers Mark.(07792041001 if easier to send picture via mobile) Quote Link to comment Share on other sites More sharing options...
Guest kevsbluecab Posted June 13, 2012 Share Posted June 13, 2012 Yeah easy to get to under the bonnet it's at the back of the engine on the right hand side of the engine. About a couple of inches lower than the air intake pipe. It's a connector plug which is sort of semi circular? It's black and just unplug it and try your motor. My mrs has gone to work in it so can't get a pic but, if you need one I could get one by the weekend, let me know. Cheers Quote Link to comment Share on other sites More sharing options...
Guest Tatty Taylor Posted June 13, 2012 Share Posted June 13, 2012 Yeah easy to get to under the bonnet it's at the back of the engine on the right hand side of the engine. About a couple of inches lower than the air intake pipe. It's a connector plug which is sort of semi circular? It's black and just unplug it and try your motor. My mrs has gone to work in it so can't get a pic but, if you need one I could get one by the weekend, let me know. Cheers Will have a look tonight and unplug it and give it a good run tomorrow on way to work and let you know the results.Thanks for your help and time ... much appreciated Quote Link to comment Share on other sites More sharing options...
Guest Tatty Taylor Posted June 13, 2012 Share Posted June 13, 2012 Yeah easy to get to under the bonnet it's at the back of the engine on the right hand side of the engine. About a couple of inches lower than the air intake pipe. It's a connector plug which is sort of semi circular? It's black and just unplug it and try your motor. My mrs has gone to work in it so can't get a pic but, if you need one I could get one by the weekend, let me know. Cheers Have sent you pm... Quote Link to comment Share on other sites More sharing options...
