Is It Tow Bar Time
Guest Dojomaster1984
What do you all reckon to putting a tow bar onto the back of the 1.6 XR3i Cabby?
A sensible choice or not? More so has anyone else done it already?
Edited by Dojomaster1984
  • Admin
Hi we have seen a few Escort Cabs with tow bars fitted and seem to be ok, one thing i would ask is why? what are you thinking of pulling as the Escort cab is not a great tow car
Guest Alanman
Bigcab had a tow bar on it when it was little cab. Pritty much took it off straight away.
A cab would be okay for pulling a little box trailer or something similar I would have thought. Anything bigger it might struggle.
Guest no1birdman
had one on mine mk4 for 15 years, pulled everything from caravan 12ft sprite to all kind of trailors, no problem
I was going to pull a simple and small box trailer tent is all, so maybey in the range of 0.5-1 ton's worth of trailer.
in what manor would the tow bar be attached to the Cab, via drilling holes and bolted or by welding it onto the chasis?
I am thinking that maybey a visit to the local garage might be in order to put thte tow bar setup on. Price range of an installation of the Cab's that have it done already?
I think that a trip to the local garage is in order. Thank you all for your help and soon there might be a cabby with a tow WORRYING OR EXCITING IS THE QUESTION lol
Guest Smiler
Mine had one fitted when I first got it. From memory it had a large flat plate mounted the bottom of the spare wheel well that curved back round at the rear valance and attached to a spreader bar that was bolted across the width of the rear valance behind the bumper. I never towed anything with it, the car was in no fit state for the road when I bought it.
