Help With Anti Roll Bar
Guest pleco
Guest pleco
Hi i need some advice Are both sides of an anti roll bar on a mk3 escort cabby the same as if i lie mine on the floor with no brackets just the bare bar one side touches the floor perfectly flat and the other is about 20mm of the floor and looks slightly a different shape :sad:
Guest will_s1cab
id say its bent, pretty sure they are supposed to be symetrical from what i can see from underneath mine
Guest pleco
i thought that but i just got the old one and placed them on top of each other and they are the same so im stumped as i thought the old one was bent the reason i bought another one but the replacement is shaped exactly the same
Edited by pleco
  • 3 weeks later...
Guest Smiler
??? That doesn't make much sense, as above I'm pretty sure they're supposed to be the same. I know the old series Landrovers used to have slightly stiffer leaf springs on the drivers side to account for the weight of the driver but I've never heard of a normal production car having it. Are both anti-roll bars from the same source (i.e. are they after-market parts)? If so, perhaps the quality isn't up to scratch. If not, then it beats me.
  • 2 weeks later...
Guest avul
I have a feeling that it maybe right, when I replaced my old one with an rs one on my mk3 I just binned it but that one was the same, one side was off the floor when the other was touching the floor. So it seems to be a coincidence that three are/were the same & u wouldn't be able to tell with it fitted to the car, just assumed it was bent & threw it out as I didn't need it. Hope this helps
Only way of knowing is to dig around on the net for some technical measurements as I doubt ford would be able to help unless some old skool guy was there.
Regards Mark
Guest pleco
I done a bit of searching on the net and the antiroll bar is definately supposed to be slightly bent on the one side and it has got to be fitted with the bend on the drivers side with the left hand threaded nut as some one fitted it the wrong way around and it rubs on the gearbox on full lock :banana_dance: so this may help other people and stop them thinking that their antiroll bar is bent
Guest Paddy
So which side is the bent side?????
The side that's bent down more so it touches the floor or the side that's bent up more so it don't :blink:
Paddy
Guest pleco
Paddy
from what i read it bends down on the drivers side straight side by gearbox
