Dizzy Timing And Running Help
Guest roitman1995
Guest roitman1995
does any one know if there is a timing mark on the dizzy or were it should idealy be to set it up with a strobe scensor
cars just had a port and polished head put on with all new valves and it fails to run right try playing with the dizzy but cant get it ryt wont idle properly and sometimes cuts out at junctions wen slowing down on the clutch
any ideas
  • 2 months later...
