Petrol Tank Mk4
Guest escott1973i
Guest escott1973i
hi there changed a efi engine to a mfi problem is the tank was rotten so left with the efi tank as the pump is inside on this is there a way of wiring the the loom from the mfi to it. if not has anyone got a tank at a good price??
cheers scott
Guest escott1973i
ended up buying a new tank!all fitted now car fired up but the cable on the gas peddle was diffrent on the efi so couldnt rev it to keep it goin then the battrey went dead grrrr on charge till tomoz now
