Guest battz02 Posted March 5, 2012 Share Posted March 5, 2012 hi guys my cab a 96 1.8 si starts up and runs great from cold but when trying to restart it after being driven it turns over forever before randomly firing it doesnt get hot when running middle of normal on the guage at worst everything works and it has been serviced every year since new any ideas ? Quote Link to comment Share on other sites More sharing options...
Guest Cooderkey Posted March 5, 2012 Share Posted March 5, 2012 Hi, I don't know the answer but, is there a way that you can track back to when the problem first started. I am assuming that you've owned the car for a while, with no problems, and now you have a problem. Did the problem start soon after you had the car serviced? If so, did they change they spark plugs, and are your plugs running too cold? ( Wrong plugs fitted ).? Is the thermostat staying closed or not opening fully. You could always take the thermostat out completely, and give it a good run, and see if it still has the bad starting problem. Just a couple of thoughts on the subject. Cheers, Burt. Quote Link to comment Share on other sites More sharing options...
Guest battz02 Posted March 5, 2012 Share Posted March 5, 2012 hi thanks for reply it has done it for 12mths or so randomly started nothing changed it went into the garage to be repaired after weeks and a large bill they say they can find nothing wrong although acknowledge there is a fault they tried ecu faults - none fuel pump ignition system etc all came up no fault i never really thought of the thermostat as it runs fine and never even remotely overheats or has the engine fan kick in will look at that tommorow Quote Link to comment Share on other sites More sharing options...
Guest battz02 Posted March 6, 2012 Share Posted March 6, 2012 may have got to the bottom of this finally it wouldnt start again this morning after starting fine and driving to the garage i popped the bonnet unplugged a sensor and its started perfect ever since just need to find out what the sensors called now to get a replacement Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted March 6, 2012 Admin Share Posted March 6, 2012 Post a pic I'm sure we can advise :-) Quote Link to comment Share on other sites More sharing options...
Guest battz02 Posted March 6, 2012 Share Posted March 6, 2012 all sorted now cost me £8 to repair and no problems starting now Quote Link to comment Share on other sites More sharing options...
Admin Paul Posted March 7, 2012 Admin Share Posted March 7, 2012 Glad you got it sorted, what sensor was it? might help other members in the future Quote Link to comment Share on other sites More sharing options...
Guest battz02 Posted March 9, 2012 Share Posted March 9, 2012 air flow sensor Quote Link to comment Share on other sites More sharing options...
