Guest will_s1cab Posted February 29, 2012 Share Posted February 29, 2012 put my new engine in bolted everything up turned the key and te engine turned over but would not fire up. found out there is no spark. Read a bit on Passionford n checked a few things like this GREEN wire to the ecu, got new plugs leads dizzy cap n arm still nothing. so im thinking it could be the coil. put a spark plug on the wire at the end and still no spark (should there be?) also ns front indicator wont work and makes a ryt stupid clicking noise from the fuse box? wiper motor onli moves very slowly then seems to start to burn out (possibly relay?) its a 1.8zvh turbo, the guy who i take my car to said when the old engine (which was knakered) got dropped in it had a spark and i havnt messed with any electrics since any ideas please as soon as this is sorted i can go for MOT CheeRS WIll Quote Link to comment Share on other sites More sharing options...
Guest AndrewElliott Posted March 1, 2012 Share Posted March 1, 2012 bad earting maybe?? Quote Link to comment Share on other sites More sharing options...
