Guest daveyboy Posted January 29, 2012 Share Posted January 29, 2012 yesterday i noticed that if i didnt have my lights on and braked the drivers side brake light worked but if i had my lights on and brake it didnt light up and knocked my rear side light out until i released the brake pedal tried changing the bulb today and now none of the drivers rear cluster works any ideas i need to get it fixed tomoz as its got its mot on tuesday Quote Link to comment Share on other sites More sharing options...
RScab Posted January 29, 2012 Share Posted January 29, 2012 Sounds like a bad earth or corroded connection easy fix Quote Link to comment Share on other sites More sharing options...
gingergman Posted February 1, 2012 Share Posted February 1, 2012 check the bulb holders, any corroision give um a quick rub with sand paper Quote Link to comment Share on other sites More sharing options...
Admin Ollie Posted February 5, 2012 Admin Share Posted February 5, 2012 hello i see you have a mk5b .i has same problem with rear lights on mine check all of above then if all else fails change the light and indicater stalk let us now how you get on regards ollie Quote Link to comment Share on other sites More sharing options...
