Guest AndrewElliott Posted October 1, 2011 Share Posted October 1, 2011 Hello quite new to this forum just been looking aroun for a while now but iv had a bit of a problem with my escort 1.6 cabrolet mk3 (1985) a wire melted and started smoking in the engine bay. iv traced it going from the batter into the loom tape and back out at the ignition switch at the steering collum. if i disconnected it at the battery end the car wont turn over but i have left it connected there and cut it at the switch side and it starts and everythin seems to work what is this wire actually for. andy Quote Link to comment Share on other sites More sharing options...
Guest dazzersrst Posted October 2, 2011 Share Posted October 2, 2011 hi m8 wot is the wire your having the problem with as you might do some damage to other wires Quote Link to comment Share on other sites More sharing options...
Guest AndrewElliott Posted October 3, 2011 Share Posted October 3, 2011 the single wire going from the + side of the battery the loom was smoking if disconnected the car wont start. i disconected the yellow wire at the ignition switch (key) that had also melted and the car works fine no problems is this just for the radio. andy Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted October 4, 2011 Share Posted October 4, 2011 yellow is ignition live only goes live when key is turned. Not sure on what other wiring it uses it. the radio is 1 of them Quote Link to comment Share on other sites More sharing options...
