Mk4 2Nd Gen To 3Rd Gen Iscv Conversion Lack Of Power Issues
Guest El87cabi
Guest El87cabi
Conversion has not quite gone according to plan, i now have great idle and throttle response but what i'd call an auto choke doesn't seem to happen though car now drives beautifully - if your driving your mum :sad:
Feels like it's holding back as you accelerate up through the gears, have swapped TPS then MAP sensors, no productive change. Checked and cleaned ACT sensor, sod all :dry:
Swapped Mixture (CO) adjustment potentiometer from donor car, gave it more get up and go but not for very long plus forget idle think stall.
I'm at a loss, the ISCV is unknown and could be buggered, i can pull the power lead off when running and the car doesn't stall, should i get a new 1 or have i missed something? Thanks, el
Guest El87cabi
Well i've figured out why the ISCV didn't kill the car when i unplugged it, when i fitted the later ISCV i neglected to open the inlet pipe on the air inlet pipe, pilock lol. neway, with that done it's improved it but i still have power loss/ the feeling she's holding back unless i tickle the throttle open gradually, a step in the right direction i guess
