Guest PaulHorsley Posted September 5, 2011 Share Posted September 5, 2011 hi everyone im in need of a little help plz,, ive just bought a mk5 escort cabby , the passenger window dosnt go up as far as the drivers side by about 4mm, and its letting the wet stuff in,, it did go up all the way and this has me stumped now, everything looks ok,just stops before its fully up ??? hope some of you can help me out, thanks in advance Quote Link to comment Share on other sites More sharing options...
Guest spenny Posted September 5, 2011 Share Posted September 5, 2011 It may just need adjusting behind the door card.. The nut might of come lose and dropped the window Quote Link to comment Share on other sites More sharing options...
Guest PaulHorsley Posted September 6, 2011 Share Posted September 6, 2011 thanks spenny but not sure where the adjuster is, im pretty sure your right though as it was ok for a while can anyone tell me how to adjust this plz Quote Link to comment Share on other sites More sharing options...
Guest shaun Posted September 6, 2011 Share Posted September 6, 2011 might have stripped the teeth on window regulator. this is quite common Quote Link to comment Share on other sites More sharing options...
Guest PaulHorsley Posted September 9, 2011 Share Posted September 9, 2011 (edited) might have stripped the teeth on window regulator. this is quite common could be right here as ive lifted now adjusted the adjuster and it only made a little differance so thinking last tooth on regulatop grrrrrr thanks any way chaps when im happy with the car i will post some piccys up Edited September 9, 2011 by PaulHorsley Quote Link to comment Share on other sites More sharing options...
